How Do You Remove Chain Tensioner Ty175
davdeborg
hi
how do you remove chain tensioner on ty175 is the circlip on the inside by the tyre
or the out side .
as new ones show it hollow where it mounts and mine is like capped on the outside any help appreciated
The TY tensioners are the same for both the 175 and the 250. The mount is on the swinging arm and the spring fit over the tensioner arm which then slips over the mounting lug. It is then secured with the spring circlip.
Tony
