Rear Shock Hydraulic Regulation Screw Setting?
lewis cosgrove
Front Forks : Recommended setting "unscrew entirely and screw two clicks"
Rear Shock : Recommended setting "screw all and unscrew two clicks"
These settings are from the actual Sherco manual (2009), just seems weird to me that they are the opposite of each other, could it be a Spanish translation error. Or is this what is actually used?
I tried "unscrew entirely and screw two clicks" on the Rear shock and it felt good? Hmmmmmm
My weight : 10.5 stone
Thanks!
All because of YOUR lack of Spanglish interpretation, I went back to verify on mine. It was all out and two clicks in and that is where I set it by feel, so I must be correct! :stoned:
Edited by copemech
Am getting confused, Splatshop said it was screw right in then 2 out for the rear shock!
"all out and two clicks in" does feel good to me when am just playing around in the garage, think i will try it next time out :)
There may also be a difference in the newer R16v shock, however mine is the standard on my '12 250 and same as yours I think.
