sykes Posted May 8, 2013 Report Share Posted May 8, 2013 hi does anyone know what size and part number for front and rear wheel bearings for this bike and the best place to get them its on a 2007 plate cheers.. Quote Link to comment Share on other sites More sharing options...
andy m Posted May 9, 2013 Report Share Posted May 9, 2013 You don't need genuine Scorpa parts, they are a std bearing size. I can't remember the size but if you remove one and go to your nearest bearing supplier they will match them up. They are same front and rear. Quote Link to comment Share on other sites More sharing options...
sykes Posted May 9, 2013 Author Report Share Posted May 9, 2013 cheers andy checked with birkets today and even they were unsure as they reckon the bearing may have changed in the later ones but said it should be the same as the sy 250 and that was 6905 front which is thin type bearings and the rear is 6004, but i suppose the only way to be sure is to knock them out and see. did a search for more info today and seen this guy selling them on the bay called Gap Bearings,,,,very cheap so wonder if they would be ok as 6004 were only £1.80 each posted. Quote Link to comment Share on other sites More sharing options...
