admacp Posted May 29, 2005 Report Share Posted May 29, 2005 I am very pleased with the responses to questions on this forum - well done everyone - it`s a gret help. My question is regarding the rear shock. The suspension feels quite stiff. I have set the spring length to 140mm and also tried it at 142mm and I have set the adjuster at the bottom of the shock to full soft as advised but it still seems pretty stiff - no chance of bottoming it out I would imagine. I have a yellow spring (is that standard?), I have cleaned & greased all of the bushes (inc. the swingarm) and they are all in perfect condition. The shock is not leaking or bent and moves without sticking. I just think that it may not be travelling the full length of travel and "packs" quickly. The bike is a 2004 280pro. I weigh around 12 stone. Anybody else think the back shock on these bikes is quite harsh? Should I contemplate a softer spring (if there is one available)? Quote Link to comment Share on other sites More sharing options...
jenkinsm Posted May 30, 2005 Report Share Posted May 30, 2005 No i always thought the opposite. All the pro's i have eva had seem to have quite a soft rear shock. There aren't any after market springs available so you'll just have to back the adjusters off i.e. so the adjusters end up nearer the top of the bike. I was always told that a good test is to stand on the bike and both shocks should go down in equilibrium. So its trial and error really. Quote Link to comment Share on other sites More sharing options...
ikb Posted May 30, 2005 Report Share Posted May 30, 2005 Don't forget you can adjust the damping!!! Theres a screw with an 8mm head at the base of the shock screw it out to soften the damping. Quote Link to comment Share on other sites More sharing options...
