jackthelad98 Posted May 13, 2013 Report Share Posted May 13, 2013 Hi, Ive got a 2010 Beta Evo 125 and have just bought a set of S3 bar ends, but the the standard beta handlbars are too narrow to fit them. Help anyone? Quote Link to comment Share on other sites More sharing options...
bilks Posted May 13, 2013 Report Share Posted May 13, 2013 Have you checked there is not a adapter on the bar ends for 2 different internal sizes,i bought a pr but were not s3's,at first i thought they were too big,but it turned out there was 2 plugs 1 over the other,remove the outer then they fitted, Quote Link to comment Share on other sites More sharing options...
0007 Posted May 14, 2013 Report Share Posted May 14, 2013 Mine never came with extra adapters, I made a little jig with a screw and a nut, put it in my drill press and hit it with a file Think it only needed a half mill removed Quote Link to comment Share on other sites More sharing options...
jackthelad98 Posted May 14, 2013 Author Report Share Posted May 14, 2013 Ok thanks i'll have a look this weekend Quote Link to comment Share on other sites More sharing options...
pindie Posted May 15, 2013 Report Share Posted May 15, 2013 Slacken the gripper right off so the sloping pieces can separate more. That's all I did. Quote Link to comment Share on other sites More sharing options...
brenin Posted May 16, 2013 Report Share Posted May 16, 2013 Hi, my Gas Gas 125 had the same problem. The internal diameter is 12mm, and on every other bar i can find (ie my Beta 250) it is 14mm, so things like S3 bar ends wont fit....i like the drilling idea, and will do that! Ian Quote Link to comment Share on other sites More sharing options...
pindie Posted May 29, 2013 Report Share Posted May 29, 2013 Make sure you lay the bike over to tip the swarf out the handlebar after drilling. Be careful you don't scratch anything or drill on an angle. You don't want a bar snapping when you land of a big drop! Quote Link to comment Share on other sites More sharing options...
