Clutch Push Rod
bulto58
Hi Guy's,
Just gone in on my M91 and replaced, mag side crank seal, and sprocket oil seal. I noticed the clutch push rod had the concaved end facing out is this right . should it be pushing on the ball bearing on the other side ?
hello yes thats normal theres a ball bearing on both ends. theres a ball bearing on the end off your clutch arm inside your magneto cover nothing to worry about. cheers bondy
