betarick Posted May 19, 2013 Report Share Posted May 19, 2013 As anyone fit s3 hardrock pegs to 2011 evo! i have a new pair but dont seem to fit as holes dont line up corectly to be in right position! Quote Link to comment Share on other sites More sharing options...
nelly1 Posted May 19, 2013 Report Share Posted May 19, 2013 i fitted them on my 09 they went on very easily Quote Link to comment Share on other sites More sharing options...
robdyson Posted May 19, 2013 Report Share Posted May 19, 2013 Had same problem on 09 sherco need to file off the back a bit Quote Link to comment Share on other sites More sharing options...
neil king Posted May 20, 2013 Report Share Posted May 20, 2013 I put some on an '11 290 just the other day with no problem. Try holding them at an upward angle, you have to push against the spring but I bet it will work for you. Quote Link to comment Share on other sites More sharing options...
ivorspider1290 Posted May 21, 2013 Report Share Posted May 21, 2013 I've fitted them to a Beta Techno and a Evo and they are a little handful to get on with the washers and spring but are well worth the effort, a few cure words cured the washers from dropping out. Quote Link to comment Share on other sites More sharing options...
twinshocktosser Posted May 21, 2013 Report Share Posted May 21, 2013 Same problem fitting them, ended up with angle grinder on them! Springs & washers suddenly fly everywhere when fitting. Took the tension out of the spring by using grip wire, then cut the wire after fitting. Good when finally fitted. Quote Link to comment Share on other sites More sharing options...
pindie Posted May 24, 2013 Report Share Posted May 24, 2013 You can cable tie the springs to keep the pressure on whilst fitting. Quote Link to comment Share on other sites More sharing options...
