hightown Posted May 21, 2013 Report Share Posted May 21, 2013 Where can I get a piston for a 198a bultaco it has a bore of 71mm. Thanking you in advance. Hightown Quote Link to comment Share on other sites More sharing options...
bondy Posted May 21, 2013 Report Share Posted May 21, 2013 bultaco uk they may have 1 in stock or they will order it for you there £165 ive just bought 1 Quote Link to comment Share on other sites More sharing options...
woody Posted May 21, 2013 Report Share Posted May 21, 2013 On 5/21/2013 at 8:56 PM, hightown said: Where can I get a piston for a 198a bultaco it has a bore of 71mm. Thanking you in advance. Hightown The later 250 ('76 on) was sleeved down from the original 244cc 72mm standard bore to 238cc 70mm standard bore. You can still use the original size 250 pistons that start at 72mm standard and there are 4 oversizes, so you won't run out of 'meat' on your liner. So you aren't limited to a 71mm piston Quote Link to comment Share on other sites More sharing options...
hightown Posted May 22, 2013 Author Report Share Posted May 22, 2013 Thanks Bondy for your reply Hightown Quote Link to comment Share on other sites More sharing options...
bondy Posted May 22, 2013 Report Share Posted May 22, 2013 ok mate no probs. just puting my 198A back together nearley all done just waiting for the exhaust to come back ive had it oven baked going to bolt the engin in tomorrow. ive just put the muduards on ill put the airbox on so there will only be the exhaust and wheels to go on the motor was runing fine before only thing ive done is put a new base gasket on. theres a copper head gasket so i can reuse it just heat it up hen touqe the head down. cheers bondy. Quote Link to comment Share on other sites More sharing options...
