deputy dawg Posted May 24, 2013 Report Share Posted May 24, 2013 Am in the process of stripping my bantam engine, would like to know if swapping the 2nd and 3rd is adequat or is it better to change 2nd for a close ratio gear?many thanks Quote Link to comment Share on other sites More sharing options...
smelling123 Posted May 24, 2013 Report Share Posted May 24, 2013 I swapped mine and it is a good improvement (and free). Personally I wouldn't be able to justify spending any money on a new 2nd gear set - although a high 4th might be nice. I run a small flywheel (electrex ignition) and that helped - it used to stall a little bit too easily in 2nd before. Here's how you do it...http://www.flickr.com/photos/76022002@N08/8583960396/ http://www.flickr.com/photos/76022002@N08/8582856835/in/photostream/ Quote Link to comment Share on other sites More sharing options...
deputy dawg Posted May 24, 2013 Author Report Share Posted May 24, 2013 thank you for posting. i was just wondering if the 2nd gear set was a huge improvement over swapping 2nd and 3rd as now would be the time to do it, or if it was just a unessasary expense. Quote Link to comment Share on other sites More sharing options...
pat Posted July 24, 2013 Report Share Posted July 24, 2013 (edited) Hi all, Little about Bantam final gearing : -which size, teeth of rear sprocket do you think is the best combo with the smallest engine- and gearbox sprockets from Rex, riding 1st gear in Pre-65 sections? 56t--60t? My weight is ~65kg. Edited July 24, 2013 by pat Quote Link to comment Share on other sites More sharing options...
