footpegleg Posted May 24, 2013 Report Share Posted May 24, 2013 Hi all I was wondering how much oil do i need to put in the gearbox, Im looking to change the oil soon, got 1litre of the good stuff not sure how much it will need if i remove the old Any ideas?? Is the clutch sticking a common prob on the sherco 2008 250 Works fine once bike has warmed up Started the bike one day all set to set of, Into 1st gear and bang, bike took of while i was not ready, and still having the clutch pulled in bike flipped out from under me but cause i had left finger still on clutch flew out under me and up in air crash right on to the clutch lever BROKEN, never done that to me before on any bike ive had. LMAO now about it If someone cn me do that they would have thought i had no xp lol Oh oh 1 more small thing One bike is warm get an awfull screech when the fan kicks in is this norm ?? Thanks again footpegleg gm Quote Link to comment Share on other sites More sharing options...
bilks Posted May 25, 2013 Report Share Posted May 25, 2013 Hi 450cc oil for your gearbox,maybe the bearing in the fan has dried out,which can happen if a jet wash has been used when cleaning the bike, As for the clutch see if its any better with the new oil in your transmission. Quote Link to comment Share on other sites More sharing options...
copemech Posted May 25, 2013 Report Share Posted May 25, 2013 Never trust a clutch on a trials bike after sitting. Put the bike in 4th gear and sit on it to rock the bike and break the clutches before starting motor is your best bet, even so use caution. Never ride the bike after washing without inspection/ protection(prior) of air filter and airbox for water entry. You gotta len the bike oer to get ols erl out! Quote Link to comment Share on other sites More sharing options...
taffe Posted May 25, 2013 Report Share Posted May 25, 2013 Hi, Had the same issue with my Beta 250 and the with my 2007 Sherco, [have the same clutch plates] I fixed them both by following the great info in the Beta forum, "Clutch Fix". A lot of work but no more stuffing around when starting the bike, I always kick it into gear with the front break on though. Worth the effort I recon. Cheers Taff. Quote Link to comment Share on other sites More sharing options...
footpegleg Posted May 28, 2013 Author Report Share Posted May 28, 2013 Thanks guys for all the replys will need to be extra careful when starting of then have got the hang now of starting it then leaving few mins while i get all gear on, helmet boots trousers shirt gloves and works fine now but I will be more aware of this Any 1 got idea of how much quantity oil i will need to do change think it a 2litre bottle ipox?? i got, recommended from shop Quote Link to comment Share on other sites More sharing options...
copemech Posted May 29, 2013 Report Share Posted May 29, 2013 Thanks guys for all the replys will need to be extra careful when starting of then have got the hang now of starting it then leaving few mins while i get all gear on, helmet boots trousers shirt gloves and works fine now but I will be more aware of this Any 1 got idea of how much quantity oil i will need to do change think it a 2litre bottle ipox?? i got, recommended from shop 450ml per change, so you got plenty. Quote Link to comment Share on other sites More sharing options...
footpegleg Posted May 29, 2013 Author Report Share Posted May 29, 2013 Hey thanks again copemech, pure wealth of knowledge u have Quote Link to comment Share on other sites More sharing options...
