mbeers6 Posted May 25, 2013 Report Share Posted May 25, 2013 Hoping someone here can help me out. I have a 2011 gas gas TXT Pro/Eco 250 with about 70 total hours. I was riding and saw that the tranny window was strawberry colored so I replaced both the water pump seal and the shaft as the shaft had some shinyness to it. Flushed tranny 3 times, everything looked fine then 3 hours later.....the seal fails again. Took it apart and saw that the seal had peeled up (see pics below). I have no idea why it did this as I followed the instructions on the gas gas video. Could it be because I used a white lithum grease vs silicon grease? The threads looked pretty bad on the impeller too. Could it b/c I tightened (counter clockwise) the WP shaft too tightly? It spun okay when put back together, but not smooth as butter or anything. So I've ordered a new seal and impeller. Has anyone seen anything like this before? Any thoughts on what I did wrong to cause this? Quote Link to comment Share on other sites More sharing options...
seavoyage Posted May 25, 2013 Report Share Posted May 25, 2013 (edited) Mark - WTF! Still making strawberry milkshakes after the rebuild? UPDATE: mbeers6 was supplied the water pump seal for the TXT and not the Pro. Confirm the part number. After comparing your photos and the parts microfiche: http://www.lewisport...o_all_parts.pdf ; and having disassembled my waterpump 2 hrs. ago (after adjusting my SHIFT SELECTOR SPRING 'ECCENTRIC' TOP SHAFT) ; On my water pump,,when assembled, the AXLE TURBINE in flush against the seal. Watch video at 1:39 showing snapring is flush with seal. http://youtu.be/AEqQvL23bgs BTW - Upon inspection my WATERPUMP TURBINE needs replacement. I just ordered a waterpump rebuild kit, but probably have to wait till next week due to the World Rounds (USA), Edited June 2, 2013 by seavoyage Quote Link to comment Share on other sites More sharing options...
