bestrcpilot Posted May 26, 2013 Report Share Posted May 26, 2013 Hello all I 'm trying to find any info on using a rdx220 piston in a ty175. The rdx220 piston has the right size wrist pin 16mm and with bore sizes starting at 69mm. My liner is already at 68mm on my stock engine and I would like to keep using it as the porting is to my liking, but would like to rebore to 70mm and make a 200 out of it. So anyone used the rdx220 piston and what needs to be done with it in order to make it work? Thanks Quote Link to comment Share on other sites More sharing options...
feetupfun Posted May 26, 2013 Report Share Posted May 26, 2013 do you mean a kdx220 piston? I have a feeling the kdx220 piston works with the Ty175 motor. Haven't heard of an rdx220 I don't think you will be able to use the standard liner for a 70mm bore Quote Link to comment Share on other sites More sharing options...
bestrcpilot Posted May 26, 2013 Author Report Share Posted May 26, 2013 Yes it's the kdx220 piston. Sorry about that . Quote Link to comment Share on other sites More sharing options...
