charlie chitlins Posted May 26, 2013 Report Share Posted May 26, 2013 Did you know that spark plug caps have quite a bit of resistance? I think about 500k. I figured this out while trying to diagnose a spark problem. I guess you're never to old to learn something. So...don't use one from the car! Quote Link to comment Share on other sites More sharing options...
0007 Posted May 26, 2013 Report Share Posted May 26, 2013 All plug caps have resistors to minimize electrical interference But it's not 500K is either 5k or 10K 500K would be a plug cap that is nearly an open circuit Quote Link to comment Share on other sites More sharing options...
bestrcpilot Posted May 27, 2013 Report Share Posted May 27, 2013 Had the Bultaco M125 out for a run around today. After about 20 minutes it quit running. after checking all normal stuff I checked the plug cap. Now this was a brand new NGK cap and it had 5000k or open. So on goes the old cap back on and the Bully started right up. Never trust a part just because. it's new Quote Link to comment Share on other sites More sharing options...
charlie chitlins Posted May 27, 2013 Author Report Share Posted May 27, 2013 All plug caps have resistors to minimize electrical interference But it's not 500K is either 5k or 10K 500K would be a plug cap that is nearly an open circuit Right! Still getting used that newfangled digital meter! Quote Link to comment Share on other sites More sharing options...
smelling123 Posted May 27, 2013 Report Share Posted May 27, 2013 5k is fairly standard - its used for noise (electrical noise/interference) supression. Should be used with CDI ignition - some of the older points ignitions dont use the resistor. Quote Link to comment Share on other sites More sharing options...
