mur Posted May 27, 2013 Report Share Posted May 27, 2013 hi guys just a quick question on the decompressor position as i am replacing the old one. it has always been at the front but can the position under the tank(normal spark plug) position be used ie. swap them round i thought i read this somewhere kind regards murray Quote Link to comment Share on other sites More sharing options...
pschrauber Posted May 27, 2013 Report Share Posted May 27, 2013 I personal would leave the plug in the center and use the other hole which is a little bit off center for the decompressor. If you ask me why there is no real reason beside it's common to do so. Quote Link to comment Share on other sites More sharing options...
guys Posted May 27, 2013 Report Share Posted May 27, 2013 The central position of the sparkplug is for a faster and therefore better combustion. Quote Link to comment Share on other sites More sharing options...
mur Posted May 28, 2013 Author Report Share Posted May 28, 2013 ok thank you very much ,will leave as is cheers murray 1 Quote Link to comment Share on other sites More sharing options...
