jon015 Posted May 28, 2013 Report Share Posted May 28, 2013 Had some vertical play on the swingarm. So pulled out the linkage that mounts to the shock. Needle bearings are pretty destroyed, anyone know the code for these and it is two needle bearings sat next to each other? Quote Link to comment Share on other sites More sharing options...
pindie Posted May 28, 2013 Report Share Posted May 28, 2013 (edited) I don't know the numbers but have you tried looking on the trials and tribulations site? They list parts and the numbers. Once you know the numbers get them from someone like Hayley Bearings at a fraction of the cost and get double seal ones if possible. Use Silkolene water proof red grease when you reassemble and it will last ages before servicing again. See here http://trialstribulations.net/index.php?main_page=product_info&cPath=34_66&products_id=909 Edited May 28, 2013 by pindie Quote Link to comment Share on other sites More sharing options...
