charlie chitlins Posted June 3, 2013 Report Share Posted June 3, 2013 A neighbor asked me to fix his kid's Yamaha PW50. It takes about a million kicks to start it...but then it seems to run OK. I checked compression (after all of the the usual suspects), and it seems quite low at 60psi. If this were a full-sized bike, I'd do the top end immediately, but I don't know if this an acceptable range for a 50. Thanks. Quote Link to comment Share on other sites More sharing options...
kevin j Posted June 4, 2013 Report Share Posted June 4, 2013 PW I had (1985 or so model, had in the late 90's) had a 'start/run switch that changed the timing so it would not start in run position, but not rev up in start position. Prevent kids starting with WOT. I have scanned service info and manuals. PM for and I can send you a file if the years match. I also changed the rear gearing to ring and pinion from a QT scooter and got about 15-20% less speed and more torque for off road use. kcj Quote Link to comment Share on other sites More sharing options...
charlie chitlins Posted June 5, 2013 Author Report Share Posted June 5, 2013 I wondered what that start/run switch could possibly do! Sending PM.... Thanks Quote Link to comment Share on other sites More sharing options...
