Vw Touran
easytigrrr
In a fashion I'd say. I have a Caddy, same shell as a Touran, obviously you need the seats out etc. May be tight to the headlining, they are tight in the van. Won't be far out. I once had a Z900 in my Caddy.
Simple answer is YES. I've done it with both modern and twinshock bikes. However, the front end will not fit due to the height. For the modern bike I removed the rear mudguard and the front wheel, and rotated the bars downwards. If you take out one of the rear seats completely, the back wheel will drop nicely into that space. I then sat the sump on a small toolbox. For the twinshock I just disconnected the brake cable and dropped the forks+wheel complete.
Mine is a seven seat version so the boot floor is a little bit higher than a five seater.
It was fine for collecting the bikes some distance from home but I wouldn't fancy the chew on week in week out for going to trials, especially in the winter.
