anotherfive Posted June 9, 2013 Report Share Posted June 9, 2013 The spring on the levers is quite weak. I use an O ring just bigger than the ball on the end of the lever. push it over this and push down to adjuster wheel and stretch it over onto the second part of the lever. Makes everything feel much better and as cheap as chips to replace. Just a fiver for that thanks !!!!! Quote Link to comment Share on other sites More sharing options...
jsp Posted June 10, 2013 Report Share Posted June 10, 2013 you sound full of useful tips, have you got any for setting a carb up on a 2012 300cc gas gas racing ? Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted June 10, 2013 Report Share Posted June 10, 2013 125 main 45 pilot 3 slide mid posn on the clip check float level at make the float bowl nut have more access to fuel Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted June 10, 2013 Report Share Posted June 10, 2013 the o rings were to stop the formula levers from flapping on mine. Quote Link to comment Share on other sites More sharing options...
