Formula Brake Tip
anotherfive
The spring on the levers is quite weak. I use an O ring just bigger than the ball on the end of the lever. push it over this and push down to adjuster wheel and stretch it over onto the second part of the lever. Makes everything feel much better and as cheap as chips to replace. Just a fiver for that thanks !!!!!
