charlie chitlins Posted June 11, 2013 Report Share Posted June 11, 2013 This '06 I bought had this little inline petcock. The previous owner said it was because the petcock leaked. I didn't know what he meant until I removed it. When I twist the lever, it twists the petcock just a bit and it momentarily leaks from where it joins the tank. I've tried holding the petcock to steady it, but it's damned tight in there! Anybody have this going on? I kind of like the little inline jobby, but I needed it for something else. Anybody know where to get another? Quote Link to comment Share on other sites More sharing options...
copemech Posted June 11, 2013 Report Share Posted June 11, 2013 See if you can fix the leak on the original by installing a standard US o-ring(slightly larger dia.), I have done this before and worked fine. Quote Link to comment Share on other sites More sharing options...
charlie chitlins Posted June 11, 2013 Author Report Share Posted June 11, 2013 Thanks, Cope. The o-ring isn't very oval on this one? Maybe my memory is mixing it up with the dozens of others I've fixed since the advent of ethanol.... Quote Link to comment Share on other sites More sharing options...
