dusty_viper Posted June 18, 2013 Report Share Posted June 18, 2013 Hey guys, After speaking with GasGas they have advise due to me being only 9.5 / 10 stone, to remove a tiny bit of oil in my forks. They have said that there should be an air gap of 165mm. What I wanted to know if should that be 165mm with the fork fully compressed with the top caps off and with the spring and everything inside? What I also wasn't too sure about was whether I need to just remove the nut on the top cap or whether I have to remove the red cap which has the holes in with a pin spanner. I'm assuming it is this one I have to remove to be able to measure it correctly but I wanted to clarify before I did. I've only owned a pair of Marzocchi push bike forks before but these have different top caps! Thanks in advance Quote Link to comment Share on other sites More sharing options...
bilks Posted June 18, 2013 Report Share Posted June 18, 2013 Hope these help Quote Link to comment Share on other sites More sharing options...
dusty_viper Posted June 19, 2013 Author Report Share Posted June 19, 2013 Hi Bilks, Thanks for the PDF's. I did look through them but unfortunately they don't provide alot of information in regards to measuring the fork oil level Quote Link to comment Share on other sites More sharing options...
