Bsa C15 Front Engine Sprocket
daveg
When I bought the smaller sprocket, it came with instructions and a thinner seal for installation behind the sprocket. I did have to cut back the case for clearance. The sprocket and seal came from C&D. I can probably dig up the seal numbers if it would be helpful.
When I fitted a smaller primary drive sprocket I removed
the lip where the chain fouls and fitted a new bearing to the
crank(which was a sealed type and removed the seal nearest
the crank).
cheers the noo Brian
hi,thanks for your help been in touch with c&d autos v.v.helpful will use again if i need parts for bsa's highly recommended.now all i need is a angle grinder and big hammer.cheers
