sherpa325 Posted June 6, 2005 Report Share Posted June 6, 2005 My 04 290 has what appears to be a small amount of radiator fluid coming out of a tiny hole [in front of the water pump ,but on the underside of the case- 2mm in dia] It is not happening all the time, any ideas before I pull it apart Thanks Quote Link to comment Share on other sites More sharing options...
jarvis sherco Posted June 6, 2005 Report Share Posted June 6, 2005 (edited) yes the seals are gone in the waterpump,what happens,is the sharft gets worn,takes the edge off the seals,normally only drip from cold.when the coolant gets warm,it stops.had the same thing on my sons o4 125,and my jarvis 290,replace it all for piece of mind......or one day your be dissapionted in not finishing the trial.......BEST OF LUCK.......BIG BEN........ Edited June 6, 2005 by jarvis sherco Quote Link to comment Share on other sites More sharing options...
colly Posted June 6, 2005 Report Share Posted June 6, 2005 happend to mine, and my water pump shaft was worn like jarvis sherco said, it came to Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted June 6, 2005 Report Share Posted June 6, 2005 Refer to the rypusa website for details on waterpump. Quote Link to comment Share on other sites More sharing options...
sherpa325 Posted June 6, 2005 Author Report Share Posted June 6, 2005 Thanks for the prompt replys, you are correct of course, have pulled it apart and ordered the parts, Thanks again Quote Link to comment Share on other sites More sharing options...
