Buying A Used -98 270Txt, What To Look For?
mic
Im going to have a look at a -98 270 txt, i used to ride many years ago and im trying to get back in the sport again, depending on the condition, can this be something to start over with or should i directly look at later more expensive bikes?
Is there any particular things to look out for in this model?
I have attached a picture of the bike below.
All help is much appreciated :)
These are basically very good solid reliable bikes. Check rear linkage and swingarm for play or tightness in bearings / movement. check forks for marks or damage. remove the sump guard and check the front and underside of the engine casings for damage or deep pitting corrosion.
Rest is just general as per any off road bike.
Just decided to add the following edit - bear in mid that these older bikes are close on 20 kg (3 stone)
heavier than the newer bikes.
Edited by dadof2
