hugh_b Posted June 23, 2013 Report Share Posted June 23, 2013 Hoping someone can help! I have a 2013 sherco 290, whilst at a trial today, on the last lap is started to "pink" and loose power/run lumpy. It has done this a couple of times before but it stopped instantly once stopped and re-started (i thought it may be something to do with the map switch as i've knocked it a couple of times/changed settings whilst riding along) Today it was over heating without a doubt, i stopped the bike and pushed back to the van. Upon inspection this evening it seems that the coolant level is just over the fins within the radiator but i'd say this has dropped slightly since i last checked. When the bikes was very hot, i could actually smell it! The fan was not constantly on however which i thought it would be? I've cleaned the carb out, checked the plug which appears to be ok. Could this be a fan/thermostat switch issue on a bike this new? Thanks Hugh Quote Link to comment Share on other sites More sharing options...
iridebikes Posted June 23, 2013 Report Share Posted June 23, 2013 it will be the thermostat just put a new one in and away you go! Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted June 23, 2013 Report Share Posted June 23, 2013 my friend had a very simular problem turned out to be a dodgy cdi Quote Link to comment Share on other sites More sharing options...
dadof2 Posted June 23, 2013 Report Share Posted June 23, 2013 Fit a bypass switch to the thermostat so you can turn the fan on if you think the bike is getting hot, this should confirm if the fault is the thermostat or not. Quote Link to comment Share on other sites More sharing options...
copemech Posted June 24, 2013 Report Share Posted June 24, 2013 A dodgy stator can make the bike run hot, possible pinging, as the incorrect ignition timing will put a lot of unburned fuel downstream the muff will likely get really warm and possible smell or smoke. This will have little to do with the fan operation or coolant temp or boilover spitting out coolant.. Just sitting at idle, if the fan runs and cycles normally, I would be looking the other direction. Hopefully the bike is still under warranty? Quote Link to comment Share on other sites More sharing options...
hugh_b Posted June 24, 2013 Author Report Share Posted June 24, 2013 I will double check the fan and stat but i'm sure it was kicking in on idle, it just seemed odd that even though the bike was so hot it wasn't on constantly and only ran for a short time before stopping. Will also investigate the stator. Thanks guys. Quote Link to comment Share on other sites More sharing options...
tony27 Posted June 24, 2013 Report Share Posted June 24, 2013 Try bleeding the system, if you get air trapped in the wrong place the fan won't go, think of what happens to your temp gauge in the car if the water level drops, it climbs until the sensor is uncovered then drops Quote Link to comment Share on other sites More sharing options...
lebowski Posted June 24, 2013 Report Share Posted June 24, 2013 Is it possible the bike was embarrassed by its 'rider'? Over 100 marks dropped at a club trial would make me boil over too.... Quote Link to comment Share on other sites More sharing options...
hugh_b Posted June 24, 2013 Author Report Share Posted June 24, 2013 Is it possible the bike was embarrassed by its 'rider'? Over 100 marks dropped at a club trial would make me boil over too.... It was more like 70....but at least I'm riding expert and not trophy hunting on the novice route teeheehehe! Quote Link to comment Share on other sites More sharing options...
lebowski Posted June 24, 2013 Report Share Posted June 24, 2013 The only trophy I'm likely to win would most likely be made of maple and I could also use it for stirring..... Not that I ever would.... Quote Link to comment Share on other sites More sharing options...
hugh_b Posted June 27, 2013 Author Report Share Posted June 27, 2013 Just thought i'd post a quick update. After some tinkering and swapping bits from a friends bike, the poor running turned out to be a faulty CDI. Malcolm Rathmell Sport were fantastic and sent out a CDI under warranty straight away so big thanks to them as I will now be riding this weekend! Quote Link to comment Share on other sites More sharing options...
copemech Posted June 28, 2013 Report Share Posted June 28, 2013 Just thought i'd post a quick update. After some tinkering and swapping bits from a friends bike, the poor running turned out to be a faulty CDI. Malcolm Rathmell Sport were fantastic and sent out a CDI under warranty straight away so big thanks to them as I will now be riding this weekend! Good on you then! As usual , seems there is exception to every rule, as CDI failures seem rare by reports, yet not(never) impossible! Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted July 1, 2013 Report Share Posted July 1, 2013 seems they were fitted with a dodgy batch of cdi,s ( as i had stated ) gasgas cadettes also have had problems Quote Link to comment Share on other sites More sharing options...
