What Size Chain?
mokwepa
Thanks guys. My pops took a vernier to his 2013 Evo 300's chain against a 520 and its spot on the money. He also doesnt run a o ring for clearance issues with his rear sets (track bikes not trials). O rings are apparently wider than standard. Thanks again.
Some 520 trial chains will look smaller because the outer dimensions are actualy smaller.
The roller diameter and the distance between the roller pins is of course the same as a stadard 520 chain.
O, X and W-chains could have larger outer dimensions and might not fit through the chain tensioner.
  • 1 year later...
