hoboarchery Posted June 25, 2013 Report Share Posted June 25, 2013 It is missing the front brake line/hose and most of the rear brake and pedal. I also need a shifter lever and clutch perch. I am thinking the pipe and seat might not be correct. If you have seen one of these please reply. I have been told that it is a rare bike in the US. Thanks Tom In MAss Quote Link to comment Share on other sites More sharing options...
chuckindenver Posted June 25, 2013 Report Share Posted June 25, 2013 (edited) you need an Engine as well, someone dropped a Yamaha Engine in the frame... rear brake lever will be tough, with the kicker lever in the way,. id be a buyer for the bike for the parts, it would cost you more then the bike is worth to make it right again the rear wheel has been flipped to accept the left hand drive, so likely the rear caliper wont stay, same for the kick stand, looks like a DT 125 or 175 dropped in with muffler. might be missing the air box assembly as well. Edited June 26, 2013 by chuckindenver Quote Link to comment Share on other sites More sharing options...
chuckindenver Posted June 26, 2013 Report Share Posted June 26, 2013 heres an original Beta Engine, left kicker Quote Link to comment Share on other sites More sharing options...
monty348 Posted June 26, 2013 Report Share Posted June 26, 2013 Oh my, you do have a conglomeration. To add to what Chuck said: The clutch perch should be Domino but most any dirtbike perch w/ lever will work. The actual seat, hidden beneath the mammoth cushion, is correct but not properly attached to the tank. The rear brake parts are the same starting with the '89 TR34 thru the early Zero. Can't say if the brake pedal will work for you with that engine but I do have a source for the pedal only. I also have a parts list I could send you. PM me if you want to know more. Some photos of my TR34 are here: Note the clutch pedal & master cylinder. http://home.comcast..../site/?/photos/ Greg Quote Link to comment Share on other sites More sharing options...
hoboarchery Posted June 26, 2013 Author Report Share Posted June 26, 2013 Guys Could this have been a 125 CC originally? They seem to have the drive on the left side in the photos I found. Quote Link to comment Share on other sites More sharing options...
chuckindenver Posted June 26, 2013 Report Share Posted June 26, 2013 no i dont think it was, though a TR35 is uncommon in the U.S. Quote Link to comment Share on other sites More sharing options...
monty348 Posted June 26, 2013 Report Share Posted June 26, 2013 From what I know the 125 had normal forks and the 240 had USD forks but don't take that as the "for sure" truth. Beta UK has some info. The TR35 came out in 1990. http://www.beta-uk.com/index.php?option=com_content&view=article&id=48&Itemid=157 Quote Link to comment Share on other sites More sharing options...
monty348 Posted June 26, 2013 Report Share Posted June 26, 2013 A closer look at this photo and it seems that the 125 did drive on the left side so "maybe" that's what you have although I don't think you have the correct engine. http://www.beta-uk.com/images/stories/tech_info_mods/1990_TR_35.png Quote Link to comment Share on other sites More sharing options...
hoboarchery Posted June 26, 2013 Author Report Share Posted June 26, 2013 Mine has painted triple clamps like the 125 in the photo. Quote Link to comment Share on other sites More sharing options...
chuckindenver Posted June 26, 2013 Report Share Posted June 26, 2013 for sure the OPs bike has a yamaha engine fitted.. i would think a 125 Beta air cooled would be tough to find. lots of parts on the girl i can use as spares. Quote Link to comment Share on other sites More sharing options...
