gb rob Posted June 28, 2013 Report Share Posted June 28, 2013 I dunno, something like a dt400 or dt of any sort (drum obviously). Im struggling getting a rear wheel and although ive got a Talon rear hub I cant justify the prices they want for a rim and spokes. Its getting a bit frustrating because the bikes good to go apart from the rear wheel. Any help would be appreciated. Cheers. Quote Link to comment Share on other sites More sharing options...
dougalthedog Posted June 28, 2013 Report Share Posted June 28, 2013 I would imagine with some mods to the swing arm locating lug you should be able to get something of a similar period to fit, although you will have the same corrosion issues as the standard TY wheel, so may cost the same at the end of the day. Second hand swinging arms are cheap enough so you could do some experimenting. How much are you being quoted for a wheel build on your talon hub, you should be able to get a rim and spokes for £150 + £70 for the build. If you had an original TY hub it would cost more as the Z spokes are more expensive than traditional spokes. Quote Link to comment Share on other sites More sharing options...
tony27 Posted June 29, 2013 Report Share Posted June 29, 2013 If my memory serves me correctly I had a pair of KT250 rear wheels for my 350 back in the 90s, neither wheel was standard when I bought it Quote Link to comment Share on other sites More sharing options...
gb rob Posted June 29, 2013 Author Report Share Posted June 29, 2013 Cheers gents. The swinging arm I have has a slot for for a lug, not the arm so this is why I was thinking late 70's DT as they mostly have to. I was quoted a bit less on the wheel build Dougal but yeah, near enough. As the bike only cost me a few hundred quid im looking for the cheap option (keep wife happy as I already spend enough on my other bikes ). Cheers Tony, i'll look into it. I actually had one of them bikes years ago. Quote Link to comment Share on other sites More sharing options...
