Front Brake Help
footpegleg
I snapped one of my bolts on my ajp master cyl front
I removed resevoir, brake cable, and caliper
(just got ma forks serviced)
Replaced brake pads....
So I first open nipple, then lever the pads open
(think at this point I pushed the pots all the way back)
Remove screw and wire clip from caliper then take out old pads
New ones put into place screw and clip back in
Remove rubber from resevoir open banjo bolt and drain the old fluid out working way down
Unscrew the banjo from caliper and remove all old fluid from there
All screws tightend back up fill the resevoir pump like mad for wee bit then open close the nipple
AHHH NO PRESSURE ATOLL
Pads and pots not moving one bit and a spongy lever grrrrrr
What I do wrong??
