toxiic_pompey Posted July 5, 2013 Report Share Posted July 5, 2013 Does anyone have a video on how to change the oil on a Gas Gas TXT Pro 05? I was speaking to some people and this was the first I had ever heard about having to change the oil in the bike after every other ride... I feel like an idiot now... and I have no idea how to change it as I've never decided to learn! Sorry! D: Quote Link to comment Share on other sites More sharing options...
wri5hty Posted July 5, 2013 Report Share Posted July 5, 2013 Look under the sump guard and you will see a hole, through that hole is a alen bolt in the bottom of the cases. Remove this to drain oil. It will have a little magnetic tip that will collect small fragments of metal floating about, small bits are usual if it has attracted a big chunk seek advice. When all oil drained reinsert bolt. Now remove similar bolt above cases, kickstart side above water pump and insert oil. about 450ml use sight window for guide (next to kickstart). Reinsert bolt. Job done. Quote Link to comment Share on other sites More sharing options...
toxiic_pompey Posted July 5, 2013 Author Report Share Posted July 5, 2013 I have Automatic Transmission Fluid DIII from Motoquip. Will that work or should I hunt for something else? Quote Link to comment Share on other sites More sharing options...
wri5hty Posted July 5, 2013 Report Share Posted July 5, 2013 Personally I don't like using ATF. I use GRO or PJ1 oil. Plenty of people use ATF I believe you just need to change it more regular. I aim for 4/5 rides before changing. But having time for maintenance is becoming a issue for me. Quote Link to comment Share on other sites More sharing options...
dadof2 Posted July 5, 2013 Report Share Posted July 5, 2013 10w-40 semi synthetic, mobil 1 5w-40 or 75w gear oil are better than atf. some atf not up to the job at all. Quote Link to comment Share on other sites More sharing options...
0007 Posted July 6, 2013 Report Share Posted July 6, 2013 Wonder if anyone knows if you can mix ATF and gear oil together Quote Link to comment Share on other sites More sharing options...
