mjb Posted July 10, 2013 Report Share Posted July 10, 2013 Hi, I've been restoring a 1977 Yam Ty250. The forks are in really good condition apart from one which has 3 spots (quite deep) and the threads are about to give up on the legs where you bolt on the mudguard bracket. Fitted new seals and clips before riding it at the weekend and the seal has gone! My questions are although I can have them re-chromed are the forks off a mono (36mm) any better? Any advice? Im assuming I will also need to have the wheel, brakes and clamps to match? do these fit directly to an twinshock Yam. One thing I notice is that the spindle is not centrally located as on the twinshock, will this make a difference? Cheers Quote Link to comment Share on other sites More sharing options...
feetupfun Posted July 10, 2013 Report Share Posted July 10, 2013 (edited) Hi, I've been restoring a 1977 Yam Ty250. The forks are in really good condition apart from one which has 3 spots (quite deep) and the threads are about to give up on the legs where you bolt on the mudguard bracket. Fitted new seals and clips before riding it at the weekend and the seal has gone! My questions are although I can have them re-chromed are the forks off a mono (36mm) any better? Any advice? Yes the TY Mono forks have a better action Im assuming I will also need to have the wheel, brakes and clamps to match? do these fit directly to an twinshock Yam. Yes you will need the clamps, wheel and brakes from the Mono, or do a lot of modification work One thing I notice is that the spindle is not centrally located as on the twinshock, will this make a difference? If you use TY mono clamps, the steering geometry will be fine, but if you use the TY twinshock clamps (bored out), there will be too little trail in the geometry. Also, using the TY mono clamps on a TY twinshock frame will severely reduce steering lock. Cheers Edited July 10, 2013 by feetupfun Quote Link to comment Share on other sites More sharing options...
twinshocktosser Posted July 10, 2013 Report Share Posted July 10, 2013 The front end from a mono will fit on without a massive amount of re engineering. However the mono yokes have more offset, so this will make the steering worse. To correct this you will have to cut the frame and alter the frame head angle. The alternative is bore out the twinshock yokes to 36mm. Quote Link to comment Share on other sites More sharing options...
woody Posted July 10, 2013 Report Share Posted July 10, 2013 I'm no good with working out geometry or trail but I've ridden a few Yam framed Majesties with with TY Mono front ends and a couple of Godden framed too, and the steering was fine on all of them, with no alteration to head angle etc. 1 Quote Link to comment Share on other sites More sharing options...
twinshocktosser Posted July 10, 2013 Report Share Posted July 10, 2013 Fair comment Woody. If you compare the yokes side by side there is big difference between them. The leading axle of the mono forks adds more to the length. It just looks a big difference when comparing in the garage. But if it rides ok then that answers the question. Quote Link to comment Share on other sites More sharing options...
earthmover Posted July 11, 2013 Report Share Posted July 11, 2013 Or you could try filling the holes in with epoxy. I've done that on a couple of sets of TY 175 forks which have 12 and 6 months use on them respectively with no hint of a leak. If you do get some other forks though, let me know, I'll be happy to take the old ones off your hands....... Mark Quote Link to comment Share on other sites More sharing options...
andy m Posted July 11, 2013 Report Share Posted July 11, 2013 Quite a few t/shock 250s about with mono forks fitted, as mentioned you can get the yokes bored to suit. Mono forks are getting hard to find though. Quote Link to comment Share on other sites More sharing options...
mjb Posted July 15, 2013 Author Report Share Posted July 15, 2013 Thanks for all your replies guys! I've heard of the epoxy trick. Might just give it a go in the meantime. Have any of you guys tried fitting new springs? Im realsistic I know Im never goint to get a modern fork feel on a 30+ year old bike unless I want to spent a lot of money. I heard Magicals do them but the website is down and Graig is not returning my email so guess he doesnt do them anymore. France Trial Classic have them on their website too. Quote Link to comment Share on other sites More sharing options...
mattylad Posted July 15, 2013 Report Share Posted July 15, 2013 Magical springs are superb, especially if combined with the alloy damper rod from Craig. Mono forks are much better overall but not "correct" for the bike. Quote Link to comment Share on other sites More sharing options...
4 stroke honda Posted July 15, 2013 Report Share Posted July 15, 2013 France Trial Classic do magical springs for the TY as they are the same as the KT250 front springs which i ordered last week and arrived in the post today in Oz so you get fast delivery as well Roger has them in his TY175 fitted with 250 forks and says they are a big improvement over standard springs Quote Link to comment Share on other sites More sharing options...
