b40rt Posted July 11, 2013 Report Share Posted July 11, 2013 Looking for some info for a friends bike, Plug BP5ES ? Should air filter element be dry or oiled ? Amal carb, chock lever ontop of body (mk2 ?) does it have air or petrol screw ? Thanks Ross Quote Link to comment Share on other sites More sharing options...
feetupfun Posted July 11, 2013 Report Share Posted July 11, 2013 Plug BP5ES flat oiled foam filter MK2 AMAL has starting device lever on top MK2 AMAL has air screw Cota 348 comes standard with MK2 AMAL concentric MK2 is the AMAL with the square float bowl Quote Link to comment Share on other sites More sharing options...
b40rt Posted July 11, 2013 Author Report Share Posted July 11, 2013 Plug BP5ES flat oiled foam filter MK2 AMAL has starting device lever on top MK2 AMAL has air screw Cota 348 comes standard with MK2 AMAL concentric MK2 is the AMAL with the square float bowl Thanks (dave?) it has the square float bowl, are they bad for wearing ? Ross Quote Link to comment Share on other sites More sharing options...
sparks2 Posted July 11, 2013 Report Share Posted July 11, 2013 Only slightly better than the Mk 1 Quote Link to comment Share on other sites More sharing options...
b40rt Posted July 11, 2013 Author Report Share Posted July 11, 2013 That good ! Quote Link to comment Share on other sites More sharing options...
