Triumph Tiger Mountain Cub Gearing For More Speed
rodcub61
What is the best gearing set up for more top end on a mountain cub , it would do around 45mph normally but I am not going off road and would like to see maybe an extra 10mph......would fitting a normal tiger cub gearbox internals from a road going fit in and give me what I want ?
Thanks in advance
I do not think you have to change the gearbox interals as top gear is 1to 1but check this You shuold check the rear sprocket and gearbox final drive sprocket to see what is fitted Most common seem to be 17t 48t rear
  • 2 weeks later...
Ive just fitted the upb gear kit to my cub,works a treat the second gear is low enough for hill climbs,and the 4th is high enough to not rev the knackers off the bike between stages.
Regards Dan
