hensley Posted July 14, 2013 Report Share Posted July 14, 2013 I just got a new randonne to use on my dairy farm. spedo lights up tach works but mph stays at zero odometer also doesnt work I didnt get a manuali printed one off but it has no wiring diagram and need a wiring diagram anyone know what the spedo problem might be? Also i would like to ger it lower so it would be more trials like currently it has 11/42 i have a 48 rear coming should i drop countershaft also and what sprocket is it (same as ttr?) also what other tuning lots of emissions on bike any tips ? Bike is a fantastic trail bike im really impressed. Quote Link to comment Share on other sites More sharing options...
lineaway Posted July 14, 2013 Report Share Posted July 14, 2013 You are the first person I`ve heard of with one. I would think you would at least need a 10t counter. Glad you like it. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted July 14, 2013 Report Share Posted July 14, 2013 Errrr the're have been a few problems with reliability, instruments being one. Quote Link to comment Share on other sites More sharing options...
hensley Posted July 14, 2013 Author Report Share Posted July 14, 2013 On 7/14/2013 at 7:06 AM, nigel dabster said: Errrr the're have been a few problems with reliability, instruments being one. I think it might just be a wire unhooked? My reasoning for buying it is it would be more veritable and reliable farm bike than a ttr125 Yamaha. Gearing right now is perfect for gravel roads and chip and seal but if id gear it down a little I could play while getting up the cows. Quote Link to comment Share on other sites More sharing options...
shercoben12 Posted July 15, 2013 Report Share Posted July 15, 2013 my friends got a scorpa and looked at the randone same engine! very similar aswell! if you remove a baffle from the exhuuast you can get more grunt and its louder Quote Link to comment Share on other sites More sharing options...
hensley Posted July 17, 2013 Author Report Share Posted July 17, 2013 Just went to 11/48 sprokets and helped low end a lot. Anyone have sugestions on exaust. The header pipe not available in usa. Thinking about empty side converter and cutting out bulge in header and unhooking breathing tube any tips if i do do i need to rejet, . Quote Link to comment Share on other sites More sharing options...
bmseven Posted July 18, 2013 Report Share Posted July 18, 2013 On 7/14/2013 at 6:25 PM, hensley said: I think it might just be a wire unhooked? My reasoning for buying it is it would be more veritable and reliable farm bike than a ttr125 Yamaha. Gearing right now is perfect for gravel roads and chip and seal but if id gear it down a little I could play while getting up the cows. Is that not illegal Quote Link to comment Share on other sites More sharing options...
sting32 Posted July 18, 2013 Report Share Posted July 18, 2013 Hensley, they didn't do the bike so you could tag it here in USA did they? when I last saw dale (kc rounds last year) he didn't think you would be able to tag it. did they finally do it so you can tag it? Quote Link to comment Share on other sites More sharing options...
hensley Posted July 20, 2013 Author Report Share Posted July 20, 2013 On 7/18/2013 at 4:39 PM, sting32 said: Hensley, they didn't do the bike so you could tag it here in USA did they? when I last saw dale (kc rounds last year) he didn't think you would be able to tag it. did they finally do it so you can tag it? I heard its a possibility for next year to tag them I dont need liscence to run back farm roads in missouri.next year the 200 will be offered.my 125 Zips down the road bout as good as my 250 yamaha xt dual sport. i was hoping to play a bit while i was going after cows but im not good enough rider to do much on it. now a 200 with emmisions work might be different. All the sandbaggers who are riding down a bit because they dont want the bigger stuff in the afternoon should have to ride a randonne there would be less clean loops or clean cards. Quote Link to comment Share on other sites More sharing options...
motovita Posted July 21, 2013 Report Share Posted July 21, 2013 Where can one find info on the 200? Quote Link to comment Share on other sites More sharing options...
hensley Posted July 21, 2013 Author Report Share Posted July 21, 2013 On 7/21/2013 at 12:16 AM, motovita said: Where can one find info on the 200? I cant find any but ive been told both 125 and 200 available next year Im not sure of the size of the 200 it may be 163cc like the scorpa 175. Quote Link to comment Share on other sites More sharing options...
