staldantes Posted July 15, 2013 Report Share Posted July 15, 2013 My rear brake pistons must have been sticking, so I headed home as direct as I could; when I got there pads were smoking. Anyway, long story short, rear brake hose melted and leaking a little. Okay so I´ll change the hose. Easy to say, the hose is navigated through the swing arm, and I have a Reenvio Hall (BT280034050) sensor making it a bitch to slide out. Was so close to just cutting of this sensor cable, but to be honest I´ve never come across this type of sensor before, so I thought I´d better ask first. Any ideas if useful, its clearly electrical, and is situated near the rear brake disc. Help idle speed, lights, timing, I googled it but didn´t get a satisfactory response. Cheers if you know p.s. whilst here, I removed my airbox and stuck on a solitary pod air filter, seems to go well. Any viewpoint on this? Quote Link to comment Share on other sites More sharing options...
jandyb Posted July 15, 2013 Report Share Posted July 15, 2013 Just the giver for the speedo... No opinion bout the airbox exept I wouldnt do it.. -Jan Quote Link to comment Share on other sites More sharing options...
staldantes Posted July 15, 2013 Author Report Share Posted July 15, 2013 Thanks for the speedy response. Wow, never seen its like before, looks like it works via magnet or infra red, anyways thanks. Quote Link to comment Share on other sites More sharing options...
jandyb Posted July 15, 2013 Report Share Posted July 15, 2013 Theres a small magnet on one of the bolts for the brake disk.. Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted July 16, 2013 Report Share Posted July 16, 2013 That unit is called a "hall effect" sensor. Basically, there is a magnet on the wheel that passes the sensor and sends a signal to the speedometer. This is the same type of sensor used by many electronic ignition systems to trigger a spark at the spark plug. Quote Link to comment Share on other sites More sharing options...
