sawtooth Posted July 16, 2013 Report Share Posted July 16, 2013 Bike is an '04 Txt Pro 280, have done seals on a beta a few years ago but am rusty now so need a quick quide? Quote Link to comment Share on other sites More sharing options...
sawtooth Posted July 16, 2013 Author Report Share Posted July 16, 2013 Its OK, this should be enough :-) http://www.youtube.com/watch?v=AP-v_c0g0mw Quote Link to comment Share on other sites More sharing options...
lineaway Posted July 16, 2013 Report Share Posted July 16, 2013 You are at the right spot, just wrong video. You want marzochi. Quote Link to comment Share on other sites More sharing options...
sawtooth Posted July 16, 2013 Author Report Share Posted July 16, 2013 Bugger, is there a marzocchi video anywhere? Quote Link to comment Share on other sites More sharing options...
jandyb Posted July 16, 2013 Report Share Posted July 16, 2013 No video I`m afraid. But you may find some info needed here: http://www.trialspartsusa.com/tech.html -Jan Quote Link to comment Share on other sites More sharing options...
jse Posted July 17, 2013 Report Share Posted July 17, 2013 No video I`m afraid. But you may find some info needed here: http://www.trialspar...a.com/tech.html -Jan The process is essentially the same, with minor exceptions, except the Marzocchi forks must be set by oil level and the GasGas forks can be set by volume of oil. If Sawtooth is not experienced, it's a good idea to have a friend who is experienced stand by to avoid beginner mistakes. We have all started as beginners. Jon Quote Link to comment Share on other sites More sharing options...
zippy Posted July 17, 2013 Report Share Posted July 17, 2013 If Sawtooth is not experienced, it's a good idea to have a friend who is experienced stand by to avoid beginner mistakes. We have all started as beginners. Jon I shall translate: "Sawtooth, this is a perfect excuse to have a friend come over and hang out in the garage/shed and share a few and do some "bench racing" and women complaining. And maybe even get the fork seals changed while you're at it." Yep we all start as beginners, best way to learn is to do it. But also know when it is time to stop and ask for assistance so as to not mess things up. Good luck, take your time, You have already done fork seals before so you may just need a few reminders of what you're doing. 1 Quote Link to comment Share on other sites More sharing options...
sawtooth Posted July 17, 2013 Author Report Share Posted July 17, 2013 (edited) Yeah thanks I should be able to figure it out, I'm an engineer plus I have done them in tbe past a while ago. Just need to know it theres anything that needs doing that might not be obvious, so far I know that I need to set the oil by measuring the air gap (is this done when the forks are compressed?) And I also know to grease up the seals and install them using some piece of plastic pipe, how much oil will I need? Anything else? Edited July 17, 2013 by sawtooth Quote Link to comment Share on other sites More sharing options...
jse Posted July 17, 2013 Report Share Posted July 17, 2013 Yeah thanks I should be able to figure it out, I'm an engineer plus I have done them in tbe past a while ago. Just need to know it theres anything that needs doing that might not be obvious, so far I know that I need to set the oil by measuring the air gap (is this done when the forks are compressed?) And I also know to grease up the seals and install them using some piece of plastic pipe, how much oil will I need? Anything else? You'll need about 270-290cc's per leg. You'll do fine. Jon Quote Link to comment Share on other sites More sharing options...
jandyb Posted July 17, 2013 Report Share Posted July 17, 2013 ... so far I know that I need to set the oil by measuring the air gap (is this done when the forks are compressed?) Springs out and forks compressed.. -Jan Quote Link to comment Share on other sites More sharing options...
jse Posted July 18, 2013 Report Share Posted July 18, 2013 Springs out and forks compressed.. -Jan And air bled from cartridge. Jon 1 Quote Link to comment Share on other sites More sharing options...
sting32 Posted July 18, 2013 Report Share Posted July 18, 2013 JSE, and to Sawtooth (op)... was this covered in one of the videos (cant watch vids from here) on Youtube, Op, search for user gasgasinfo on youtube, gasgas usa parts dealer and importer created DVD's for us 'mericans, which is our owners' manual and tech source, recently he's put most the the chapters (if not all) up on Youtube, which shows you MANY things you might ever need to do maintenance wise, on the gasgas trials... Quote Link to comment Share on other sites More sharing options...
sawtooth Posted July 18, 2013 Author Report Share Posted July 18, 2013 The bleeding air from the cartridge is something I know nothing about? Quote Link to comment Share on other sites More sharing options...
sting32 Posted July 19, 2013 Report Share Posted July 19, 2013 The bleeding air from the cartridge is something I know nothing about? Older bikes this wasn't as known, the cartidges have changed so newer than 08, you (should probably always) pump cartridges a few times while in fork with some oil in... since we're going to measure the fluid to a set level, the set level assumes that the "dampening" parts have no air in them, when you clean them you should have probably pumped all the cruddy oil out the system. on my 2010, it took 5 or 10 pumps to feel I got the air out, then you do what they say to do. now on that 04, forks were made by different than now company, or least design was different, seems there is a "add so many cc's" to the tube and your are done, least that is how I always did it when I had my 04-06 pros... Quote Link to comment Share on other sites More sharing options...
