jfc Posted July 19, 2013 Report Share Posted July 19, 2013 My son wants to fit Boyesen reeds to his 2013 Evo 125! Do you think he will notice any difference in the bike? And if so is it a trade off, do you loss anything in the power range as well as gain? Quote Link to comment Share on other sites More sharing options...
peterh Posted July 20, 2013 Report Share Posted July 20, 2013 I fitted Boyesen dual stage reeds (before they produced the trials specific ones) to a 09 Evo 125 and found they improved the low end torque/power and responsiveness at the low end without affecting top end. I followed a process of re-jetting the carb as well and was quite happy with the result. When I went to sell the bike, I put it all back to original specs and that was when I really noticed the difference - it had lost the low end responsiveness so immediately, replaced the Boyesen reeds and jets and clip position to my specs as I felt it was a much better bike with them in. I have subsequently put Boyesen dual stage in my 2012 Evo 200 and also happy - and had to re-jet the carb to compensate. But it is always hard to be completely objective as no dyno readings etc. - the most noticeable difference was taking them out of the 125 and setting back to original specs - the bike felt different. After all, I have to be able to justify the expense and time and fiddling to the "cheque book holder" - so perhaps I have to believe the bike is better! 1 Quote Link to comment Share on other sites More sharing options...
charlie chitlins Posted July 20, 2013 Report Share Posted July 20, 2013 Boyesen has the only 2-stage reed. They hold the patent. It seems silly to buy anything else. Any bike with a reed can be improved by their addition, IMO. Quote Link to comment Share on other sites More sharing options...
peterh Posted July 20, 2013 Report Share Posted July 20, 2013 Boyesen now advertise trials specific reeds - 1) super stock reeds to match OEM specifications; 2) their "power reeds" dual stage reeds (the ones I have fitted) ; and 3) carbon fibre reeds matched to specific trials bikes. http://boyesen.com/TRIALS Quote Link to comment Share on other sites More sharing options...
jfc Posted July 20, 2013 Author Report Share Posted July 20, 2013 Will the bike definately need to be re-jetted when new reeds are fitted, if so for uk riding what jets will we need for a 2013 evo 125 Quote Link to comment Share on other sites More sharing options...
liviob Posted July 23, 2013 Report Share Posted July 23, 2013 You will at the very least need to adjust the air screw. You may need to change the pilot jet. Its nothing complicated and the reeds give instructions for the tuning adjustment. Quote Link to comment Share on other sites More sharing options...
steve fracy Posted July 24, 2013 Report Share Posted July 24, 2013 Carbon tech reeds are a must, only air screw adjustment needed Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted July 24, 2013 Report Share Posted July 24, 2013 Will the bike definately need to be re-jetted when new reeds are fitted, if so for uk riding what jets will we need for a 2013 evo 125 fitted a few sets of Boysens to various bikes never re jetted in the uk. whilst they really helped the sherco on my Beta they weren't as dramatic. Quote Link to comment Share on other sites More sharing options...
steve fracy Posted July 24, 2013 Report Share Posted July 24, 2013 Dabster you ever tried the new Carbon Tech ones?? Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted July 24, 2013 Report Share Posted July 24, 2013 once I think, you rate them? are they dual stage? Quote Link to comment Share on other sites More sharing options...
charlie chitlins Posted July 25, 2013 Report Share Posted July 25, 2013 My '06 came with V-Force reeds from the previous owner. Anybody know anything about them? Quote Link to comment Share on other sites More sharing options...
liviob Posted July 25, 2013 Report Share Posted July 25, 2013 (edited) The v force reeds work very well. They made the bike feel like it was 25cc bigger engine on the bottom. They made a very noticeable improvement to button torque and quicker RPM spool up of my 02 rev3 250. Midrange was slightly improved with no change to topend. The only drawback to them is that you must modify the intake manifold to accept the v force reed. The protrusions which fill airspace in the intake track must be removed. Edited July 25, 2013 by liviob Quote Link to comment Share on other sites More sharing options...
outlaw dave Posted July 25, 2013 Report Share Posted July 25, 2013 We have a number of Betas and Shercos out with the new carbon reeds fitted, with everybody reporting improvement at the bottom end - some models may need a one notch leaner position on the needle. Quote Link to comment Share on other sites More sharing options...
copemech Posted July 26, 2013 Report Share Posted July 26, 2013 We have a number of Betas and Shercos out with the new carbon reeds fitted, with everybody reporting improvement at the bottom end - some models may need a one notch leaner position on the needle. Dave, I have been looking for reports on the carbons vs the duals stage. " Improvement is a subjective term, however wit some preferring things a bit more smooth and docile, and others a bit more rippy! Any other experience to add to your observations? Quote Link to comment Share on other sites More sharing options...
liviob Posted July 26, 2013 Report Share Posted July 26, 2013 I have used the Boyeson Dual stage reeds in my 09 290 EVO . If your looking for a softer, smoother, much more flexible stall resistant bottom then use the #112 reed. I have not used the #116 reed yet "which is the reed that all of the shops sell", but hear it delivers a more robust response than the stock reeds and the #112 reeds. Quote Link to comment Share on other sites More sharing options...
