n_redd Posted July 20, 2013 Report Share Posted July 20, 2013 Took her out for a little ride today, discovered my coolant is way low. What does the 94 249 take? Probably need to check the transmission oil as well. How and to what level does the oil go, and what does it take? Quote Link to comment Share on other sites More sharing options...
lineaway Posted July 20, 2013 Report Share Posted July 20, 2013 I`m going by memory. You just need anti-freeze for aluminum at 50/50 mix. The oil was maybe 500cc. There is a level indicator screw on the shifter side cover by the small fantic symbol. Hope that makes sense. The biggest difference from `93 to `94 was the front rake was brought in 1 degree for better turning. Quote Link to comment Share on other sites More sharing options...
n_redd Posted July 20, 2013 Author Report Share Posted July 20, 2013 What type of oil should I use? Quote Link to comment Share on other sites More sharing options...
lineaway Posted July 20, 2013 Report Share Posted July 20, 2013 I use Maxima 75 wt light gear oil. Quote Link to comment Share on other sites More sharing options...
