retro Posted July 28, 2013 Report Share Posted July 28, 2013 Hello, I need to have a swing arm bolt made. Can someone tell me the grade of bolt that I should use? Thanks Much! Retro Quote Link to comment Share on other sites More sharing options...
b40rt Posted July 28, 2013 Report Share Posted July 28, 2013 Anyone with the equipment and knowledge to make it will know what to use. Quote Link to comment Share on other sites More sharing options...
suzuki250 Posted July 28, 2013 Report Share Posted July 28, 2013 (edited) Mild steel should be fine (EN1), but you would probably be better with EN8 as the thread would be stronger It very much depends on the application & spindle diameter. Edited July 28, 2013 by suzuki250 Quote Link to comment Share on other sites More sharing options...
paulc76 Posted July 28, 2013 Report Share Posted July 28, 2013 EN8 is the way to go for a trials bike EN24 if you want to go belt and braces Quote Link to comment Share on other sites More sharing options...
htrdoug Posted July 28, 2013 Report Share Posted July 28, 2013 I measured my Fantic 309 aluminum swing arm bolt that I had to cut out and found a almost perfect bolt on Fastenal's site,just had to trim some threads off,works so good I've almost forgot I did it.May not be uber light aluminum but it fits and was available THE VERY NEXT DAY! Quote Link to comment Share on other sites More sharing options...
