Rev3 Revving Out Of Control?
danyorks
I noticed the rubber hose between the carb and air box was loose - after sorting that it still revved out of control (by this point I had messed with the idle screw) I shut it off and couldn't get it start again - no spark now!!! I have checked the wiring all ok, I am now getting a really weak spark, not enough to fire it up?? Never had this problem before?
Not likely you developed two different problems at the same time
Perhaps In a frenzy you injured the kill switch when the engine was screaming
The boot on the air box side could not be the cause, there is no vacuum on that side
