Do You Use O Ring On Amal Flange?
davdeborg
just been doing some research etc and just ordered a new rubber manifold flange from inmotion
as the carb face which fits to flange on inlet manifold is smooth do you use a o ring as shown in manual as there is
no cut out in flange on carb for o ring to fit in ?
or does carb just butt up against the rubber flange ?
help appreciated
My early 250 and the first 325's were flange fittings had no O ring but they had 627 Amals made in Spain Other Amals 626 and 930 I used on my BSA do have O rings and are made in the UK
cheers mate yes that explains it as mine is a early 325 and it has a 627 carb many thanks for help just Haynes manual shows o ring
cheers
