mokwepa Posted August 6, 2013 Report Share Posted August 6, 2013 Hi guys Im putting on a new chain only because my sprockets show a tiny amount of wear. Can sprockets be flipped? Should I flip or leave as is? Quote Link to comment Share on other sites More sharing options...
zippy Posted August 6, 2013 Report Share Posted August 6, 2013 I am not looking at my sprocket at the moment but I think each side of the sprocket is machined differently. Quote Link to comment Share on other sites More sharing options...
axulsuv Posted August 6, 2013 Report Share Posted August 6, 2013 (edited) Always replace chains and sprockets as complete sets , They will last much longer .... New chain on old sprockets or new sprockets with a old chain will wear out really fast , the pieces are meant to mate together at a much closer tolerance than most think . If your chain is adjusted correctly , grab it at the back edge of the rear sprocket , if you can pull the chain away from the sprocket at all , it is worn . And the sides of sprocket teeth wear too ! Cheap insurance to save your cases and a crash .... And DO NOT flip your sprockets !!! They will wear really fast , wipe out your new chain and/or derail the chain .... And many of them are meant to be installed in one way , slight offsets etc, etc.... Edited August 6, 2013 by axulsuv 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted August 6, 2013 Report Share Posted August 6, 2013 You can just replace a chain if the chain is worn and sprockets are good. If the sprockets are worn, then it`s a complete set needed. 2 Quote Link to comment Share on other sites More sharing options...
