bondy Posted August 10, 2013 Report Share Posted August 10, 2013 anybody know the paint code of the bultaco blue from inmotion? and the white paint on the 199Bs Quote Link to comment Share on other sites More sharing options...
noel063 Posted August 11, 2013 Report Share Posted August 11, 2013 You have asked this before.Why don't you look through previous post. Quote Link to comment Share on other sites More sharing options...
bondy Posted August 11, 2013 Author Report Share Posted August 11, 2013 not for bultaco blue i havant from inmotion its not skyblue its a diffrant code. Quote Link to comment Share on other sites More sharing options...
hightown Posted August 11, 2013 Report Share Posted August 11, 2013 hello Bondy I have used Ford Electric/ Monza blue from Halfords. This is the nearest I can get. Hope this helps. Hightown Quote Link to comment Share on other sites More sharing options...
bondy Posted August 11, 2013 Author Report Share Posted August 11, 2013 hello mate its a touch up with brush i need but i do have a can of bultaco blue its just a few bits that need touching up seeing as ive stript the bike i may jus mask and spray the bits. Quote Link to comment Share on other sites More sharing options...
bullylover Posted August 12, 2013 Report Share Posted August 12, 2013 Bondy, if you spray some paint into a small bottle or even the spray can lid and let it dry a bit then use a brush. If you want to clean the brush out you will need some acrylic lacquer thinners or even some acetone might work. Graham. Quote Link to comment Share on other sites More sharing options...
bondy Posted August 12, 2013 Author Report Share Posted August 12, 2013 cheers Graham am on it the bikes stipt at the back end so am spraying the bits that ne doing. took the engin to be vapour blasted today. and took the new conrod to be fitted also today. 1 Quote Link to comment Share on other sites More sharing options...
