Petcock Assembly
j__h
Due to ethanol in the gas I needed to clean out the petcock as the On was partially blocked (still flowed well) and the Reserve was almost fully blocked with very little flow.
Once I finished cleaning out the ports, it seems the way it goes together would not provide such a good seal. Can I get confirmation on the ordering of the parts, especially the wavy metal washer against the orange seal. I have it laid out the way I think, such that it would fit together from left on bottom to right on the top.
I agree with everything you have said, I even usually do take pictures just forgot for this one.
The ordering you suggest is what makes most sense to me also I just thought it was initially placed were it is now but as you mention it would seemingly not provide a seal.
