breagh Posted August 13, 2013 Report Share Posted August 13, 2013 Hi folks. Got an 07ish of the above. No really wanting to put a new clutch in it as it doesn't slip . However it doesn't clear cleanly even right in. I've tried a number of semi synthetic oils and it doesn't seem to make any difference. Advice welcome.. . Quote Link to comment Share on other sites More sharing options...
janwillem Posted August 13, 2013 Report Share Posted August 13, 2013 I think step 1 is to put in the oil that is recomended for your bike, maybe you have to change it a second time after running it for an hour or so. Step 2 would be to look at the adjustment of your operating mechanism, is the free play set up right? Step 3, if you have a hydraulic clutch, sorry not familiar with your bike, bleed the system. If this fails, you will have to change the plates. When the wrong type off oil was used, it is possible that the coated plates have soaked up the oil, you can't get rid off it so a change will be ineviteble. Good luck. Quote Link to comment Share on other sites More sharing options...
arnoux Posted August 14, 2013 Report Share Posted August 14, 2013 It's a very common problem with that Yamaha motor - there was a heap of posts on ThumperTalk about it in the YZ250 configuration. it's not just a Scorpa thing! Scorpa improved it in 08, but still with some drag issues. This is the setup from the italian X4 Team: Clutch mods for 06/07 only Scorpa SY250F, 2008 SY250F do not need any modifications as a different stack is used. The stacking of new clutch discs can improve the sensitivity and avoid possible clutch drag. Here, below, follow the order to insert discs: - Disk Friction 3XJ-16321-00 5NL-16325-10 5NL-metal disk- Aluminum spacer (Scorpa OEM plate) 5NL-16325-10 5NL-metal disk- - Disk Friction 3XJ-16321-00 5NL-16325-10 5NL-metal disk- - Disk Friction 3XJ-16321-00 5NL-16325-10 5NL-metal disk- - Disk Friction 3XJ-16321-00 5NL-16325-10 5NL-metal disk- - Disk Friction 3XJ-16321-00 We found a little shim washer (cant remember the thickness but it was quite thin) placed on top of the hub towers, in combination with this clutch plate combo above did the trick. You will have to do a bit of trial and error to get the right shim washer thickness to get the right balance between slip and drag, but it does work. Check the ThumperTalk Forums - search under $2 fix for Yamaha clutch YZ250. Quote Link to comment Share on other sites More sharing options...
breagh Posted August 19, 2013 Author Report Share Posted August 19, 2013 (edited) Thanks for the replies gents. I'm happy enough with the way it's adjusted and biting point. When it gets really hot is when you notice It especially trying to find neutral. I think a strip down is on the cards. Cheers. Edited August 19, 2013 by breagh Quote Link to comment Share on other sites More sharing options...
loonal Posted October 1, 2013 Report Share Posted October 1, 2013 Might be a bit late, but drilling the holes in the clutch boss really does work. I have doe it on one Scorpa Trials & 2 T Rides all to good effect. http://www.thumperfaq.com/clutch_mods.htm LOONAL Quote Link to comment Share on other sites More sharing options...
breagh Posted November 2, 2013 Author Report Share Posted November 2, 2013 (edited) Hi Loonal, Had it to bits today and saw the holes were already drilled. However,I tried a wee bit" fine tuning" with my drill. All I can say is that it is better in the cul-de-sac. See how it goes tomorrow. Post Trial Big improvement ,drag almost eliminated,can even get neutral now at a standstill. Edited November 4, 2013 by breagh Quote Link to comment Share on other sites More sharing options...
loonal Posted November 6, 2013 Report Share Posted November 6, 2013 (edited) So Breagh what was the mod? Holes did you make them bigger or put them on the correctside of the boss? Most people forget to think about which way the clutch spins... LOONAL Edited November 6, 2013 by loonal Quote Link to comment Share on other sites More sharing options...
breagh Posted November 8, 2013 Author Report Share Posted November 8, 2013 I never though about that! Yes I did make them slightly bigger,but not them all just one in each group of three. Not much ,if it was a mm I would be surprised. As I only Trial it and you would have to be a brave man to really give it gas I can't see this doing any damage. Thanks for the tip,best it's ever run.. Quote Link to comment Share on other sites More sharing options...
exman Posted July 3, 2024 Report Share Posted July 3, 2024 On 10/1/2013 at 12:31 PM, loonal said: Might be a bit late, but drilling the holes in the clutch boss really does work. I have doe it on one Scorpa Trials & 2 T Rides all to good effect. http://www.thumperfaq.com/clutch_mods.htm LOONAL Expand I know I am a bit late but where are those holes should be positioned? i'm just about to buy SY250F and it seems I'll need all those mods to make it jump right. Quote Link to comment Share on other sites More sharing options...
