Kickstart Rachet
bondy
From your picture that does appear to be correct. However the shaft also needs to be preloaded with spring tension in order for that ratchet to return . So long as the shaft returns or "springs back" and the ratchet locates back to where I see it in your picture then its installed correctly.
The 199a case will not fit the 250. the crankcase openings are a different size.
Steve
hi steve yes the the spring is preloaded and dose return. am just testing to see if i can get the gearbox to go in correct am using a 199A crank case has my 198A cases are away being cleand so want to get it spot on dont fancy doing it twice. i have all the new bearings ready to be fitted. and the crank is having a new conrod and new bearing. cheers.
