Changing Front Pads 2010 Txt Pro
shercoben12
Drop the front wheel
remove the retaining pin(s) for the old pads
remove the old pads
At this point I usually gently push the caliper piston back in a little with a flat blade screwdriver to open up the gap a little for the new pads
insert new pads
replace retaining pin(s)
reinsert front wheel
tighten axel bolt
ride bike
10 minute job.
Loosen the one retaining bolt.
remove caliper from fork.
spread pads before installing new ones.
Install pads.
Put caliper back on.
Try the brake lever.
Might try the water trick on hot pads to break in.
So, with the old pads in the caliper you should be able to spread them with a large screw driver. What have you used? And how much pad was left on the old brake pads? If they were all the way to metal, this might not be as easy as we thought!
You don't need to remove the front wheel, just the caliper. Remove the master cylinder Cap and push the pistons back. My pistons wore a hole through the pad and touched the disc. I had to remove the pistons and make them flat again lol. If your pads wont go in your pistons arent fully back
Main thing is, if the pads wont easily retract the "pistons" that are in the caliper, then 99 of 100 times you have the lever adjuster setup wrong, and the "PLUNGER" that is in the Master Cylinder is not returning to "at rest" position, which allows the hydraulic fluid to flow from cable to resivior. if it ISNT just he adjuster, then it is a smidge of dirt behind the boot, behind the C-Clip that holds the "plunger" and stops it from being able to come fully out on travel.
OR the 1% that I have seen, you have a problem in the caliper, the pistons came out too far,on ONE side and are now "cocked" or crooked and wont go back in. the pistons are made of something that is a fragile as glass/Plastic so DO be carefull how you pry on the pistons themselves, that is why we usually have the "old" pads in there and then jam around with a screwdrivers. I stick a flat blade in mine that is slightly bigger than the gap, and twist the screwdriver and the pads will move "apart" so it shouldn't take excessive force!
All done thanks guys. Had to put old ones back in and put a chisel in and Prise the pistons back. They are also bedded in as well. I just put them through a few cycles (accelerating and then stopping) I did 6 of those (going along in 5 th and stopping and they gradually got sharper) then on the last ones when they were really hot poored cold water over them (water trick - thanks line away ;) ) and now they are lovely and powerfull and sharp!
