Leak Where Petcock Meets Tank.
charlie chitlins
As I recall, older shercos came with a gasket on the petcock. Might try combining the two to get a good seal if you can find the gasket.
Other thoughts include trying a good RTV sealer like three-bond. I think it is fuel resistant, however it is not alcohol resistant, so must cut the alcohol out of the fuel.
I do not know if it is possible to find or make a thicker seal ring of square profile that may work.
  • 2 weeks later...
I've had the same problem with a 2006 125 so I used a rubber grommet to seal it but then found out it is leaking from one of the treads in the tank as well!!
I'm going to attempt to remove the threads and manufacture a plate to go inside the tank for the petcock to bolt to. Plus a little bit of that sealer copemech suggested!
