mick Posted August 22, 2013 Report Share Posted August 22, 2013 Hi all I am thinking of moving my condensor to up by the coil under the tank, and while I am at it put a second one there. Can anyone suggest a type of condensor they have used which has worked OK and where to get it? Looking around there are lots of different types from various bikes. I was thinking one with a bracket to make it easy to mount, is there a specific specification I should look for? Mr. Nolan has lent me one with .59 Italy 10F stamped on it Mick Quote Link to comment Share on other sites More sharing options...
feetupfun Posted August 22, 2013 Report Share Posted August 22, 2013 There is nothing unique about the properties required for a condenser on an SWM trials bike. The capacitance required is the same as for any other set of ignition points that have faces of a similar diameter and run a similar gap. Because of this you can safely walk into an auto electrical shop and look at the range of "points/coil" condensers and select one that has a nice mounting lug. Where you might have trouble is finding a shop that actually sells condensers for points/coil ignitions, because for many years, cars, motorbikes, chainsaws, lawnmowers, and outboard motors have not used points/coil ignitions. The last one I bought went on my 1968 Bultaco and it was a condenser made for a 1960s Mercedes car engine. It was BOSCH brand and has a nice big lug and a long piece of cable 1 Quote Link to comment Share on other sites More sharing options...
sherpat Posted August 22, 2013 Report Share Posted August 22, 2013 I used one for a 1978 VW 1.6L. That was a completely arbitrary year and model, but the physical size was about right, it had a mounting tab and wire, and the local NAPA had one in stock. I made a small bracket to bolt on the coil mount. It worked great, no more fouled points. Quote Link to comment Share on other sites More sharing options...
