tman427 Posted August 24, 2013 Report Share Posted August 24, 2013 Just wonddering about how many hours you can put on a 2011 Evo 4t 300 before you should cahnge the oil and filter? The Manual claims about 30hrs which seems like a lot. I was figuring around 15 to 20hrs? Also, if it is just practice hours verses an event if that makes any diffrence as you would run a tad faster between sections for an event. Thanks Quote Link to comment Share on other sites More sharing options...
nzralphy Posted September 3, 2013 Report Share Posted September 3, 2013 30 would be right if you have quality oil and mostly ride lower-mid revs. If you rev the tits off it then 15-20 sounds right Quote Link to comment Share on other sites More sharing options...
chuckindenver Posted September 4, 2013 Report Share Posted September 4, 2013 a 2 day event= 4 to 6 hours.. 30 hours is norm, after breakin.. i just rode a 2 day event with a 2 mile loop, 11 sections per loop,, 4.5 hours time on the bike...hour meters are cheap.. Quote Link to comment Share on other sites More sharing options...
